Пт янв 04, 2019 15:23
Rim Type: Carbon clincher, tubeless-ready, Zero Bead Hook design
Rim Material: Carbon fibre
Rim Width: 30mm external, 22mm internal
Front Spoke Pattern: Radial/Three-cross (2:1)
Rear Spoke Pattern: Three-cross (1:1)
Spoke Count: 24 front, 28 rear
Spoke Type: DT Swiss Revolution
Nipple Type: DT Swiss Pro Lock hexagonal
Front Hub: Alloy body, 15mm thru-axle and 28mm QR end cap options included
Rear Hub: CNC machined alloy body, high quality DT Swiss 240 internals with quick engagement ratchet system cassette, includes SRAM XX1 11-speed freehub and 142 end caps
Sram XX1 and XD compatible (Shimano freehub available seperately)
Front QR: Roval RWS
Bearing Type: Sealed cartridge
Assembly Method: Hand-built
Total Wheelset Weight: 1370g
