Пн дек 26, 2016 21:59
livestrong1986 писал(а):А почему на 1-12 сразу перешёл?
Вт дек 27, 2016 06:23
Сб янв 28, 2017 12:47
Вс янв 29, 2017 00:37
livestrong1986 писал(а):это что?
Поздравлять тебя , или просто фото?
Чт апр 20, 2017 10:17
Чт апр 20, 2017 11:30
Snk писал(а):https://twentysix.ru/blog/stuff/129242.html
11-50 кассета Sunrace MX80 на 11 скоростей
Чт июн 01, 2017 12:22
Чт июн 01, 2017 14:56
Пн июн 05, 2017 13:59
Пн июн 05, 2017 14:09
Не нравится довольно большой свободный ход педалей после паузы во вращении
Why should we care about the number of engagement points, something often touted in high-quality hubs and ignored in lower end versions? Because your riding experience is greatly affected by the quality of your freehub. Beyond precision bearings and tight tolerance machining, the number of engagement points will be the most noticeable aspect of a particular hub. The difference between an 18-tooth star ratchet and a 72-tooth will be quite noticeable. With 18 points of engagement spread over 360 degrees of rotation, a hub, and thus your pedals, will move 20 degrees before it reengages and begins rotating the wheel after coasting. A 72-tooth Chris King hub will only see 5 degrees of movement in the same scenario. Although you may have never noticed, this 15-degree difference in engagement can really change how the bike feels. It removes that slight play in the pedals before reengagement and gives the rider a positive feeling of almost instant acceleration and connection to the road.
Пн июн 05, 2017 14:10
